Threads: 41
City: Shepherdsville, KY
Hi all
I have two questions on a Philco 16 B cathedral:
1 Is the top/sides walnut?
2 Does the grain run from front to back?
I have a cabinet that needs the veneer replaced (it has been removed by someone else ![Icon_sad Icon_sad](https://philcoradio.com/phorum/images/smilies/icon_sad.gif) ) I have never put veneer on a cabinet but have to try sometime I guess.
So wish me luck
Joe
Hi Joe
Yes, and yes.
Let us know how it goes putting the veneer on the top/sides, OK? It seems as if it would be easy to apply veneer with the grain running vertically, but not so horizontally (front to back).
Threads: 41
Man I am having trouble finding walnut with the grain going the correct direction.
Has anyone ever ordered any veneer. I have contacted two places and no luck but I will keep hoping
Joe
Yesterday evening, I had my very first experience applying self-sticking veneer to a 44B cathedral cabinet. The grain is running the wrong way (side to side instead of front to back), but the owner didn't care as long as it had new veneer. It isn't the easiest stuff in the world to work with.
Make sure you have a small roller tool if you use this type of veneer. I didn't, and have a few small air bubbles left that I can't get to completely press down. ![Icon_sad Icon_sad](https://philcoradio.com/phorum/images/smilies/icon_sad.gif) At least I managed to line it up correctly so that there is no gap anywhere between the front arch and the new veneer.
The owner of this cabinet furnished the veneer; I do not know the source. I do know that I have not yet seen any veneer you can buy that has the gran running in the direction we need that you can buy in the extra wide widths that would be required for a continuous sheet to go around a cathedral cabinet.
Threads: 15
City: Anacortes, WA
Ron--any way you can lance the bubbles with a very thin knife blade to 'burp' the veneer, a la wallpaper?
I don't recommend that, because then you have to fill the cut with wood putty, which will show afterwards. (I know because I tried, and it didn't work. Then I had to fill the cut with wood putty.)
However, I discovered a trick today: I had bought an old iron at a yard sale this past weekend for 50 cents. I purchased this specifically to iron veneer onto substrate, in order to speed the setting time. I learned this from watching a video made by "Hagstar" John H.:
http://hagstar.phanfare.com/slideshow.as...id=3128328
I've been slacking off on my studies this week to work on a Philco 44B cabinet, as mentioned previously. The cabinet was in really bad shape, and the grillework was delaminating badly. I used my yard sale iron to help glue the veneer back onto the front panel and front arch.
Anyway, figuring I had nothing to lose, I decided to try using the iron on the side of the cabinet where some air bubbles were showing.
It worked! It seems to have made the air bubbles go down.
I turned the iron temperature all the way up when using it on the cabinet. The iron does not scorch or burn the wood if you work carefully.
Threads: 41
Hi Ron
Is the selfsticking veneer really wood or is it some plastic stuff?? ![Icon_confused Icon_confused](https://philcoradio.com/phorum/images/smilies/icon_confused.gif) I was going to suggest the knife job but you answered before I asked. ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif) I am going to still look for a while but may be forced to do something else.
Joe
It's really wood, and it's thin enough that it bends quite easily. In fact when my friend whom I am repairing the 44B cabinet for brought the veneer over here, it was rolled up in a box.
Threads: 72
City: Linn Creek, MO
Another good option is the paper backed veneer. Paper backed veneer is available 48 by 96 inch sheets, so you can run the grain from front to back. I have purchased veneer from this fellow on Ebay and have received good service http://cgi.ebay.com/120533411147 A sheet this size will do several radios, so you might be able to share with someone else.
M R Radios C M Tubes
Threads: 41
Hi Steve
Thanks for the info on the veneer, and he is here in Louisville, I sent him an email to see if I could pick it up local.
thanks for the tip
Joe
Philco 91 Restore Code ??
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM |
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM |
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001).
It can be in tens of pF....morzh — 03:13 PM |
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM |
No, that cannot be the 47.
The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM |
I have changed the title of this thread from Philco 91 Schematic.
I have gone through most of the cap replacements. I...dconant — 01:26 PM |
Here is an online transistor substitution site…
Ron462ron — 08:44 AM |
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM |
Hello Tim,
I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM |
Restoring Philco 96
Mike;
The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM |
There are currently 3212 online users. [Complete List] » 3 Member(s) | 3209 Guest(s)
