HELP. Just need to indentify this cabinet
I have looked all over but cannot seem to locate a match on Philco's site for this cabinet. No markings are apparent to me to indentify it.
Anyone know? No comments on the mess in and on the cabinet, it doesnt belong to me
    [attachment=18304]
Welcome to the Phorum!
Icon_wave
I did not see one like this in the Photo Gallery so it is likely a more recent model than 1960.  Perhaps someone will recognize it.
It took awhile but I think I found one at least close to what you have. It's a TV console cabinet.
https://www.google.com/search?biw=1051&b...8033518295
http://www.lotnut.com/app/item.html?guid...94a75ad268
Here is a better link I think.
I believe you are correct sir! Thank you very much
Good sleuthing Mike!!! Icon_thumbup
There are currently 3224 online users. [Complete List]
» 1 Member(s) | 3223 Guest(s)
