Star-lite FM-530
Hello,
So I have this Star-lite that's been sitting around that I picked up at a antique place awhile back, I cant seem to find any info online about it. Is anyone familiar with them? There is a very small schematic printed on the bottom but i was hoping to find one online I can read. Any help is appreciated. Thanks in advance.
It's Sam's photofact #710-11 (1964). You can buy it from Sam's or ask around and someone might be able to scan it for you.
Thanks again Terry!
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
There are currently 2145 online users. [Complete List]
» 4 Member(s) | 2141 Guest(s)
AvatarAvatarAvatarAvatar
