39-55 wireless restoration
I’m relatively new to the forum, but I thought I would find an existing thread on restoring these wireless receivers.  Am I simply missing something? I did a couple of searches and turned up very little information.
If you are not finding anything using the built-in Phorum search, then do the following:
Go to google.com
In the search box, type in Philco 39-55 site:philcoradio.com
This turns up a number of threads on the 39-55.
If you still aren't getting enough info, try changing your search to Philco 39-116 site:philcoradio.com
While the 39-116 has two SW bands in addition to AM, the Mystery Control circuitry is basically the same as the 39-55.
Just a few 39-55 threads Google turned up:
http://philcoradio.com/phorum/showthread.php?tid=171
http://philcoradio.com/phorum/showthread.php?tid=999
http://philcoradio.com/phorum/showthread.php?tid=2705
http://philcoradio.com/phorum/showthread.php?tid=3197
http://philcoradio.com/phorum/showthread.php?tid=4337
http://philcoradio.com/phorum/showthread.php?tid=6893
http://philcoradio.com/phorum/showthread.php?tid=6872
91H Code 126 Restore
There are currently 4782 online users. [Complete List]
» 2 Member(s) | 4780 Guest(s)
