Threads: 140
City: Lansdale
State, Province, Country: PA
All, Just started on this RCA 15X.. Outside looks pretty good..
[Image: https://farm5.staticflickr.com/4853/3997...bce5_b.jpg]
Inside looks OK... but noticed looks like most if not all caps have been replaced.. Values do not match schematic..
[Image: https://farm5.staticflickr.com/4915/3997...aa69_b.jpg]
Good news is all coils, output Transformer and IF's check out fine..
Other problem is the schematic I have is not that great.. Values are hard to read..
So on to Recapping and checking resistors..
Skip
(This post was last modified: 02-01-2019, 12:24 AM by vecher.)
Threads: 268
Threads: 140
City: Lansdale
Thanks Terry..I will take a look..
Skip
Threads: 54
Skip;
It looks like someone recapped your radio back in the 1960s, that was when Sprague caps used those red and yellow labels. Believe it or not they may still be quite viable, they were starting to switch over to using either plastic film as a dielectric, or a combination of plastic film and paper by then. A guitar amp that a friend of mine has is full of caps like these, unfortunately the resistors are badly drifted off spec so the amp still needs an overahaul. However if the values are just plain wrong, such as using a .05 in place of a .01, I would go back to the factory specs.
(This post was last modified: 02-01-2019, 12:26 AM by Arran.)
Threads: 140
City: Lansdale
Arran, Ok Thanks I will recap anyway.. Looks like some were not even close.. Probably only values they had at the time..
I think at lease one of the IF's was replaced as it matches the 2nd If used in a 36X or the 2nd production run of the 15X..
Has 6 leads instead of 4...
Skip
Threads: 140
City: Lansdale
Well, Finally Recapped.. Had to replace quite a few Resistors too.
So on to power up.. Need to hookup the Loop antenna first.. Almost forgot..
Skip
Threads: 30
City: Wellborn Florida
Sorry I am late to the party.
Threads: 140
City: Lansdale
Thats OK Thanks This helps too..
Skip
Threads: 140
City: Lansdale
Ok powered up.. at 120 Volts reads 280 MA So all is good.. Plays well across the band.. Very sensitive little radio..
Now on to case a little GO-JO and polish and this should clean up nicely..
Skip
Threads: 416
City: Boston
Those are nice little sets, have a real classic look to them. You will have a nice one.
Threads: 140
City: Lansdale
Thanks
Here is radio with just a little Go-Jo cleaning Not to bad..
[Image: https://farm8.staticflickr.com/7872/4004...f2de_b.jpg]
Skip
Fine job.
Threads: 140
City: Lansdale
Threads: 416
City: Boston
I like the Red Dot with the line dial indicator.
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
