Threads: 140
City: Lansdale
State, Province, Country: PA
All, Just started on this RCA 15X.. Outside looks pretty good..
[Image: https://farm5.staticflickr.com/4853/3997...bce5_b.jpg]
Inside looks OK... but noticed looks like most if not all caps have been replaced.. Values do not match schematic..
[Image: https://farm5.staticflickr.com/4915/3997...aa69_b.jpg]
Good news is all coils, output Transformer and IF's check out fine..
Other problem is the schematic I have is not that great.. Values are hard to read..
So on to Recapping and checking resistors..
Skip
(This post was last modified: 02-01-2019, 12:24 AM by vecher.)
Threads: 268
Threads: 140
City: Lansdale
Thanks Terry..I will take a look..
Skip
Threads: 54
Skip;
It looks like someone recapped your radio back in the 1960s, that was when Sprague caps used those red and yellow labels. Believe it or not they may still be quite viable, they were starting to switch over to using either plastic film as a dielectric, or a combination of plastic film and paper by then. A guitar amp that a friend of mine has is full of caps like these, unfortunately the resistors are badly drifted off spec so the amp still needs an overahaul. However if the values are just plain wrong, such as using a .05 in place of a .01, I would go back to the factory specs.
(This post was last modified: 02-01-2019, 12:26 AM by Arran.)
Threads: 140
City: Lansdale
Arran, Ok Thanks I will recap anyway.. Looks like some were not even close.. Probably only values they had at the time..
I think at lease one of the IF's was replaced as it matches the 2nd If used in a 36X or the 2nd production run of the 15X..
Has 6 leads instead of 4...
Skip
Threads: 140
City: Lansdale
Well, Finally Recapped.. Had to replace quite a few Resistors too.
So on to power up.. Need to hookup the Loop antenna first.. Almost forgot..
Skip
Threads: 29
City: Wellborn Florida
Sorry I am late to the party.
Threads: 140
City: Lansdale
Thats OK Thanks This helps too..
Skip
Threads: 140
City: Lansdale
Ok powered up.. at 120 Volts reads 280 MA So all is good.. Plays well across the band.. Very sensitive little radio..
Now on to case a little GO-JO and polish and this should clean up nicely..
Skip
Threads: 415
City: Boston
Those are nice little sets, have a real classic look to them. You will have a nice one.
Threads: 140
City: Lansdale
Thanks
Here is radio with just a little Go-Jo cleaning Not to bad..
[Image: https://farm8.staticflickr.com/7872/4004...f2de_b.jpg]
Skip
Fine job.
Threads: 140
City: Lansdale
Threads: 415
City: Boston
I like the Red Dot with the line dial indicator.
New member
Love the pic! I'm southern IL, so wouldn't be much help and Bob Anderson is very good on those, but lives in Chicago are...TV MAN — 05:25 PM |
:thumbup:klondike98 — 04:56 PM |
With these values I think you are OK; the Cmax for this tube is 40uF.
Your Vbb could rise a bit, but probably not too mu...morzh — 04:53 PM |
BTW, someone had replaced the original 20uF/20uF filter cap with a 47uF/33uF cap. Do you think these values are safe on ...bluecap — 04:33 PM |
You're correct. I was misinterpreting the key position. I now know where it is, and things are making sense. I appreciat...bluecap — 04:29 PM |
I think Morzh has a good thought. Check the key position. The under chassis diagram in the Philco info shows an “H” for ...klondike98 — 04:25 PM |
Philco 630csx power cord
Yes, the third wire goes to the stud on the side and is separate from the other two.
I've usually used cloth covered ...Tynwald — 03:09 PM |
New member
Have you tried Alabama Historical Radio Society?
They possibly could recommend someone.
I remember a name of Dee Hanes...morzh — 03:08 PM |
Nope, he can’t tell me the dimensions. Looks like I won’t be buying it.jrblasde — 02:38 PM |
Hello Joseph ,
It sounds like you found a good seller and yes shipping is really expensive !
Sincerely Richardradiorich — 02:16 PM |
There are currently 2758 online users. [Complete List] » 5 Member(s) | 2753 Guest(s)
