Hallicrafters Model S-107
My wife's nephew came by last night and brought me a couple of items. He sometimes comes across stuff he thinks I might like. The first one is a Hallicrafters Model S-107 Radio/Receiver. I know nothing about this, bit it looks to be in fairly nice condition. It definitely needs cleaning and probably recapping, but the power cord seems very flexible. I did plug it in and had dial lights and a very quiet hum. Can anyone tell me anything about this? I see it has antenna screws in the back, two with metal jumper. I also saw a little rubber grommet on the top rear of the cabinet, don't know what that is for? Anyway, I'll post a couple of pictures later when I'm at my computer. He also brought me a really clean VOM. It's a RCA model WY- something or other. I checked it out after he left and found all it needed was a new electrolytic cap, the pots. cleaned, and the wafer switches cleaned and DeOxit'd. Once I did those, it was working perfectly! It even came with all three leads! Now I can add it to my stable of restored diagnostic tools. I'll post a couple pics of that too. Currently waiting for four new tires to be installed on my truck.
Gregg Icon_thumbup
its apparently not a bad set.. but am no expert.
i hare restored a half dozen hallicrafters from s38 to s53.
lookie there
http://wd4eui.com/Hallicrafters_S_107.html
the shorting is disabled if you use a long wire to terminal 1.
,, not sure on the rubber grommet.
i actually can appreciate how it extracts out the front instead of the rear.
Nice set Tubes are fairly common. On the back if the jumper is connected to ground it is set up to use a single piece of wire as a ant. You can remove the jumper and use twin lead to hookup a dipole ant.Back on June 06 2015 I posted a pdf for the S38E the ant hookup would be the same. Enjoy your new set.
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2480 online users. [Complete List]
» 5 Member(s) | 2475 Guest(s)
AvatarAvatarAvatarAvatar
