46-1226 factory finish ?? satin of gloss
i have a 46-1226 code 122 it has a satin finish do you know what was stock finish thanks....john
Hi
The original finish would have been gloss lacquer.
thank you.... can the finish be put on by brush or spraying only this is my first redo i was 10 yr old when it was made it an old friend
john
Best results will be achieved by spraying. Lacquer dries very fast, so brushing would be rather difficult, I would think.
thank you for your help.. the forum is a great help to the seniors many who lestened to philco when they were new....captian midnight- the shadow and others that played with your mind not like today mindless tv
Model 27-84 BUZZ?Humm?
Hello Bruce, First all do mean a 37-84b ? Did you take any before and after pictures ?radiorich — 01:59 AM
Philco 630csx power cord
There are currently 3739 online users. [Complete List]
» 1 Member(s) | 3738 Guest(s)
