Philco Model 732
Hello all,
I am new to the forum and I'm not even sure if I should be here...
I am in New Zealand where the Philco model numbers are not the same as the USA ones.
Nevertheless, I'm hoping that someone may be able to point me in the direction of a schematic for a Philco Model 732 (S/No: 14053)
Valve Lineup: 7B7, 7A8, 7B7, 7B6, 5Y3, 6V6
Broadcast plus 4 SW bands covering 49M to 16M
Perhaps there is a USA model which has the same lineup and I might glean some clues from that.
Any suggestions welcome.
Many thanks!
Hi and Welcome!
Sure you can be here! It maybe a big help to post a picture of your set. Or you could take a look in the Gallery to find it.
Hello Terry,
Thank you for your encouraging words!
I will take some more shots tomorrow of the "innards", but here it is as I received it.
Also, I may be a wee bit slow, but how do I access the Gallery?
Cheers1
Noel
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Based on some information found it was made in 1947 by Philco New Zealand. Sets for Philco New Zealand appeared to be manufactured by Dominion Radio & Electrical Company (DRECO). Other than this information I'm not able to find much unfortunately... I'd say based on cabinet design alone it looks most like a model 46-132 but it's not the same since the US model is AM and it appears only one SW band.
http://www.radiomuseum.org/r/philco_732.html
http://www.radio-restoration.com/Philco.html
http://www.trademe.co.nz/Music-instrumen...299571.htm (good picture for restoration reference)
Brian Mattson
Coon Rapids, MN
Here you go! http://www.philcoradio.com/gallery/
Philco 91 Tuning Condenser
