RCA 811K question
Hello fellas,
Have a question concerning my 811k .
Swapping transformers and seem to have lost my wire ID tags on a couple wires coming out of the transformer.
These are the 2 largest dia wires.
One goes to pin 2 on the 6J7 tube and the other goes to pin 7 on the 6J7 tube.
Any chance these wires could be swapped or are they specific to these connections?
Apparently my id tags came off as I removed the transformer from the chassis.
Any help would be much appreciated.
murf
As long as you have abt 6vac across the two wires your good. Phase relationship doesn't matter.
Hi Terry,
Just want to make sure I solder them in right the first time.
Sounds like it can go either way.
Thanks to all,
murf
All,
The Philco 39-6 posts have been split off into a thread of their own.
https://www.philcoradio.com/phorum/showt...?tid=19786
I was wondering if that was gonna happen.    Sorry.   Icon_redface
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
