Ron's Transitone TP-5-I
Earlier this month, I picked up a nice Transitone (Philco) TP-5-I.
Last night, I began restoration work on it.
A look at the chassis:
As you an see, a portion of the speaker cone is missing.
Rear view:
And how it looks underneath:
As you can see, it is jam-packed under the chassis. As I did with Sam's 40-501 Phonograph with Philco, I will take a radical approach to this chassis.
The Transitone TP-5-I was introduced in January 1939 along with several other compact Transitone model table radios including the TH-4, TP-4-I, TH-5, TP-10, TP-11, TP-12, TP-14 and TP-15. These Transitones were much more compact in size than previous Philco table model radios, and they all used variations of the same stuffed, cramped chassis.
Since all of those wires are of the rotten rubber-coated variety, they all need to be replaced.
I have found that the best plan of attack is to remove as much as possible from underneath and start all over from scratch. Attempting to replace one wire at a time in a chassis as cramped as this will result in other wires getting damaged while trying to reach obscured solder terminals with other wires and components in the way.
So, last night...
I began disconnecting and removing wires and components.
Tonight, I more or less finished up that job.
To be able to reach everything and replace the remaining wires, I will need to remove the speaker, the dial scale, and the pushbutton assembly. Removing the pushbutton assembly will also make it easier to clean.
Both IF transformers and the oscillator coil have been removed. Unfortunately, one of the oscillator coil terminals came off from the coil form while I was trying to remove one stubborn wire. The little wire from coil to terminal did not break, however, so this coil might still be usable. We shall see.
Good looking little radio. With that rotted rubber wire makes sense to do it like you did the 40-501 chassis.
Thanks for sharing! Looks like a lot of restoration work.
Answers my question if those were loctal tubes....
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Ron, Looks like the bottom of my PT-25 I assume its a basic design..
[Image: https://farm8.staticflickr.com/7845/4710...c596_b.jpg]
I had to do what you are doing.. Replace every wire..Just got it done today and put on bench.. Worked first time.. Doesn't seem to be to particulate about placement of wires.
Mine is not the greatest of rewire jobs.. But it works..
[Image: https://farm8.staticflickr.com/7921/4672...62a4_b.jpg]
Skip
(03-22-2019, 04:58 PM)vecher Wrote:  Ron, Looks like the bottom of my PT-25 I assume its a basic design..
(snip)
And that is all that matters. Icon_smile
Yes, the same basic chassis was carried over into 1940, many 1941 models and even a few 1942 Philco Transitone models.
What a crammed little chassis!  I would probably be looking for a liquor bottle half an hour into it!  Take care, Gary
Tonight's progress:
I removed the speaker, dial pointer and dial scale.
I unmounted (but did not completely remove) the pushbutton assembly. I've even started replacing wires. I found that the antenna coil tests OK so that is a good thing. I'll have to replace the original hank of antenna wire as it is badly frayed.
Though tough to work on I always think on the little sets not everyone could afford the top of the line. Wonder what the original owner listened to on that set..............
Hi Ron
Are you rewiring it exactly as it was from the factory? I've read that the wire routing paths were crucial to ensuring the best performance and deviating from it could introduce hum.
Thanks
I think I see another candohm tutorial in the future as well...
Paul (WyTex) - The new wiring probably won't end up being run exactly as it was from the factory, but will be close enough. I've done this before to a couple of those cramped little chassis and they turned out just fine. Icon_smile
Gary - I checked the Candohm and the resistances are slightly higher than listed on the schematic, so it is going to be reused. It should not be too difficult to replace if need be.
Rather than actually working on the radio this evening, I put together an under-chassis view of the parts which will help me get everything back together...and will hopefully help others as well.
Here it is.
Why Philco never published one of these for their little Transitone/Philco Transitone models, I do not know...
Helpful hint: Right-click on the image above and select View Image. You can then see it in full size if you wish. You can then right-click that and download the image if you want to.
Good diagram, quite Philco style Icon_smile
What do you use, Ron, to draft? A CAD or some Office Draw? Doesn't look like drawn by hand.
91H Code 126 Restore
There are currently 4369 online users. [Complete List]
» 1 Member(s) | 4368 Guest(s)
