Philco 46-1201
How does one remove the chassis from the cabinet?
Hi Bill, Open the radio slot. On each side there there is a detent pin. Push them in. They will release the chassis which will swing up. Also there are two clamp brackets which have to be lossened. They are on the rear of the radio at the bottom. Bill
91H Code 126 Restore
