True Blue (Arcturus)?
https://www.russoldradios.com/blog/true-blue
Arcturus seemed to have a time figuring out what to label their tubes with number and suffixes changing frequently, but this one is just wrong - -
There are currently 10085 online users. [Complete List]
» 1 Member(s) | 10084 Guest(s)
