Help Me Identify My Sister's Radio
My little sister in Chicago has a Philco that vaguely resembles a coffee table. It has a board protuding out on the bottom on one side, like a shelf, ending in a curved shape. It has another such board on the top. The top has a speaker on the side where the protuding boards are, in between them. It also has a headphone set.
Does it look like http://www.philcoradio.com/gallery/1938a.htm#u ? If so, it is a 38-15 from 1938.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Actually, I think it is. I sent her an email with the picture just to be sure. THANKS!!
Philco 91 Tuning Condenser
There are currently 9759 online users. [Complete List]
» 1 Member(s) | 9758 Guest(s)
