116B - Your Opinion - All Welcome
But, not necessary to tell me it's my radio "do what I want". If I did that, I would not be asking - -
So I told you all about getting a really nice 116B for $35 on CL the other day. The chassis is done and the cabinet has the first coat of finish lacquer. Now I am waiting (and waiting - -) for the proper Philco decals to come in from RD.
This is how it looks:
It has not been sanded, so it is not smooth. That will come later.
The question I have is about the dark color. It is (now) a real dark walnut - with a slight reddish hue, really only noticeable in bright light. It looks black in room light.
Here is how it looked when found:
It is slightly darker, but not black in bright light. Keep in mind that some "yellowing" of the original finish has made it darker than when it left the factory.
I have never liked the "black" on the shouldered tombstones.
Tough call, but, do you think I should make it darker? It would not take much effort prior to the final finish.
No. No, I don't.
As you know, tinted lacquer always looks lighter in bright sunlight. In spite of the sunlight, I think it looks just fine as is. Icon_thumbup
I like that!
I know NObody is going to argue with "Mr. Philco" Icon_clap
Yeah, right. Icon_rolleyes
Seriously...I'd like to find a Mohawk equivalent to the color you have mixed for the dark portions of Philco tombstones. I do think the color you have come up with is more authentic than the near-black Extra Dark Walnut.
According to the gallery pic, it does not have black.  So, no, I would not make the sides darker. A handsome specimen, it is.
Looks great to me also Russ and I'm sure not going to argue with Ron!
Well, OK then.
Now if the decal would just show up.
I just use gloss enamel black rattle cans.. Easy peezy  Screwy Yikes
I think that is proper Russ...
Icon_smile
Leave it as it is looks great!
There are currently 7483 online users. [Complete List]
» 2 Member(s) | 7481 Guest(s)
