What do I have here?
I purchased this at an estate sale with no accompanying information. The tube chassis has stamped “D 14170”. Is that the model #?
Mark W
Welcome to the Phorum!
That's not a model number - more likely a serial number.
Info here on identifying Philco radios:
https://philcoradio.com/library/index.ph...ion-guide/
Alternatively post a few pictures and we can help.
Icon_wave
Hi could you tell me what replacement capacitor would I use for BR3045A 3 cap mfds volts 450 thank you James
Hi James and welcome.
To answer your question I'll ask you a question, what Philco model are you servicing??
Part numbers are sometimes hard to sort out when you don't not know what they go to.
Not sure if the post goes w/the 1st three maybe Bob can move it and change it to a separate thread.
Any ideas on what model this is?
Looks like a 42-365K to me. The three tuning bands seem to match as does the cabinet.
Thank you, Bob!
We do not have a good photo of that model in our gallery. If you could take a few shots of it face on, it would make a nice addition. You can post it here or send it to Nathan Slingerland. Thanks much!!!
More pics
Thanks!!
There are currently 10875 online users. [Complete List]
» 2 Member(s) | 10873 Guest(s)
