1936 Rca C8-19 video
Wink
finally got the chassis done the audio is over powering the microphone in my phone this set is LOUD!  Icon_biggrin
playing oldies from WRUS am 610.
https://www.youtube.com/watch?v=liocSBeD...e=youtu.be
Icon_thumbup
Nice job.
Great job!!!
There are currently 9967 online users. [Complete List]
» 1 Member(s) | 9966 Guest(s)
