Atwater Kent/Kiel Table Radio
Offer accepted.  Now I own this Atwater Kent 55C in the Kiel table.  It'll have to sit for a while since i have too many other projects in process and another big one to start soon.  Radio and cabinet are not in bad condition.
Congratulations! Icon_thumbup
very cool!!  would you mind scanning that AK documentation (or if its pasted to the frame, photograph it close up)?  I have the same table and radio.  Congrats!
Me too on the pink paper.
I presume you're talking about the pink colored instruction sheet?  I will remove it as it is held in place by only 2 staples which I will want to remove anyway.  Then I can scan it for you.
Congratulations, those are a unique piece of furniture and radio rolled into one Icon_thumbup
I have a HiRes scan of the installation instructions but i don't know how to upload a multi megabit file.  if you guys want to pm me your email addresses, I can email it to you.  or I can upload it to DropBox.
Here is a link to Google Drive for a High Resolution copy of the instructions (for those who wanted it.)
https://drive.google.com/file/d/1YSdKfmn...uthah/view
There are currently 3463 online users. [Complete List]
» 1 Member(s) | 3462 Guest(s)
