35-1285 Record Changer Repair
Threads: 1
City: Wylie
State, Province, Country: TX
05-15-2019, 11:15 AM
Hi all! I'm new to this forum, but have been a Philco Collector for about 30 years. I'm currently working on a 42-1008 console with a non-functioning record changer. I feel pretty dumb about this, but I need to remove the turntable and can't seem to figure out how to get it loose from the changer mechanism. I've tried pulling up on it, but it seems to be firmly attached to the base. I suspect that it is fairly easy to get off. The Philco Record Changer Manual says only "remove turntable".
I suspect that this may have been covered in a previous post, but my searches haven't turned up anything useful.
Threads: 271
City: Wilsonville
State, Province, Country: OR
I can’t answer your question but...
Welcome to the Phorum!
Threads: 569
Possibly Kirk could help.
Kirk!!!
Threads: 25
City: Louisville, KY
On my 48-1256, there is a machined screw with a 5/16" hex head holding the platter on. It's screwed horizontally into the brass bushing that the platter spindle is in, ( underneath the changer base). Look and see if yours has a similar screw. This model has the cute, small 6" platter, and if yours has the same, it probably also has the same screw.
(This post was last modified: 05-15-2019, 08:24 PM by Jake Blake.)
Threads: 1
City: Wylie
Jake - I don't see any kind of set screw. My turntable is almost 10" in diameter. I do see a nut at the very end of the spindle (underneath). I've been reluctant to remove it, because it looks like it holds a lot of stuff together, but will give it a go...
Threads: 1
City: Wylie
Threads: 25
"Jake - I don't see any kind of set screw. My turntable is almost 10" in diameter. I do see a nut at the very end of the spindle (underneath). I've been reluctant to remove it, because it looks like it holds a lot of stuff together, but will give it a go..."
Okay. I'm seeing this late, but yes, it sounds like a different set-up, so use caution. Good luck bud!
Threads: 1
City: Wylie
OK, let me try this another way...
I posted a different thread earlier this month asking for help removing the turntable on my 35-1285 record changer. I'm a little puzzled, because I got almost no response to the post. I know there are lots of people out there who have worked on the Beam of Light changers (although I will admit that most of the internet stuff that I've found on this subject was written 10-15 years ago). My changer is in a model 42-1008 code 122 console.
In any case, the problem is pretty basic. The Philco repair manual says simply "remove the turntable". I've tried prying, hammering, and cussing, and so far all I get is about 1/32" up and down movement of the turntable. I'm afraid to pry too hard, for fear of cracking the cast turntable or damaging the spindle. It's like there's a hidden c-ring or something, that keeps the turntable locked on the spindle. My suspicion is that the turntable is supposed to lift off easily, but has gotten frozen to the mating parts from years of rust or gummed up lubricants.
Everything else on the changer seems to be in surprisingly good condition (except for the rubber parts, which have cracked and fallen off, or have turned to sticky gum.
I any case, I desperately need advice, before I break something....
Threads: 337
City: lawrenceville nj
I don`t know about the 35-1285
but all the bol`s I had platter just pulled off they just sit on a pin
if you moved it try a little pb on shaft go up then down few times
sam
Hi,
I have merged both of your posts into this thread.
Please read the Phorum Rules here:
https://philcoradio.com/phorum/showthread.php?tid=4586
Multiple threads on the same subject are not allowed per Phorum Rules.
A lot of our restoration experts were at Kutztown earlier this month. Now it's a holiday weekend. Hopefully someone will chime in soon with some helpful advice. Edit: Someone already has while I was typing.
Thanks for your patience.
Threads: 25
" . . . I(n) any case, I desperately need advice, before I break something.... "
I have one more idea on this.
Is the platter spinning freely? If it ISN'T, try pointing a heat gun at the bushing underneath to see if that loosens solidified lubricant that could be holding the platter on.
. . . although, frankly, I don't think this has been a problem with changers of this vintage. It is mainly known to affect BSR changers from the 70s.
Threads: 1
City: Wylie
Sorry, Ron. I wasn't thinking. I'll do better in the future
Threads: 1
City: Wylie
Jake - Thanks for the suggestion to apply heat with a heat gun. I heated it for about a minute (from the top, aimed at the base of the spindle) and then used a pair of large flat-blade screwdrivers to pry up on the turntable platter. It took a little more force than I was comfortable with, but it did free itself from the bushing and popped off. Looks like it was held on by petrified lubricant. Nothing broke! What a relief! Thanks again, and thanks to everyone who responded.
I have done some basic tests on the Beam of Light arm, and so far it looks like everything works, but I'll have to do a lot of work before I can be sure. Every piece of rubber will have to be replaced, and there are lots of rubber parts on this thing...
Threads: 25
"Looks like it was held on by petrified lubricant"
YEEAAAAH! Great bud!
Threads: 337
Ramjet
Every thing may seam good
But photo sensor will not produce sound Properly
And most likely need replacement
Sam
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
There are currently 4510 online users. [Complete List] » 1 Member(s) | 4509 Guest(s)
