38-690 chassis and tuner rubber washers?
Was wondering if someone could tell me the correct chassis mounting washers along with the RF subchassis mounting washers for a 38-690? I see Renovated radios list them for 690/116, but dont know if that means 37/38-690...
If you meant these
http://www.renovatedradios.com/product.php?product=269
these are not for RF subchassis.
And these are specifically for 690
http://www.renovatedradios.com/product.php?product=278
What messed with me is they both say chassis support... so the 1st ones are what support the chassis in the cabinet, I’m assuming 4 of them, and the set of 3 are for the tuner sub-chassis that sets on the main chassis?
To support the subchassis you need three - one rear and two sides.
There was also (haven't found it) a small grommet that goes in the tuning cap itself for the rotor support. But it is not for the chassis itself and you might or might not need it.
Trivia - the 2 side supports are slightly different from the one in the back.
Yes I think the back one has longer internal cylinder than the sides.
Philco 91 Tuning Condenser
There are currently 9421 online users. [Complete List]
» 1 Member(s) | 9420 Guest(s)
