Sears silvertone question
Hello I do have a schematic. Don't remember where I got it from. I'll have to dig it out of the file and get back to you.
Do you have the same one with the wire recorder?
I have the same model as described at https://www.radiomuseum.org/r/sears_roeb...01831.html Silvertone 8125 Ch= 101.831-1 Type 47 It's a beauty and complete except for the turntable. I've been searching everywhere to find schematics. Alignment details would also be great.
Until I can get the schematic uploaded to send, and be advised it's not the greatest in regards to clarity,
here is a detailed restoration of one of these consoles in case you haven't seen this.
https://antiqueradios.com/forums/viewtop...r+tone+101
Here is schematic I have and info on alignment. Sorry some pics are sideways.
https://i.imgur.com/e67fLoM.jpg
https://imgur.com/cfbIj7J
https://i.imgur.com/G2AHGwe.jpg
https://i.imgur.com/qwGLjnJ.jpg
https://i.imgur.com/0izQtuL.jpg
Thanks for the files and your link to the restoration discussions of this Silvertone.
