EH Scott Philharmonic AM/FM
Threads: 49
City: Allendale, MI
Threads: 49
City: Allendale, MI
Not shown in the previous post is the amplifier/power supply. Here it is and disassembly has begun in preparation for re-chroming. Notice the twist lock electrolytics. These are dual 30 mfd at 500 volts. By 1940, capacitors certainly had shrunk from what they were a couple of short years earlier.
Threads: 69
City: Kansas city, MO.
Great radios. I have the E.H Scott all wave 23 I restored last year. Very labor intensive.
It's good you can still find a place to get the chassis chromed. That will be a very nice radio when your done.
Congrats.
Threads: 49
City: Allendale, MI
Ready for the chrome shop.
Wow, a lot of work there. But the end result will be well worth it.
I need to do the same to my McMurdo Silver MP VI power supply.
Threads: 154
City: Westland, MI
Nice radio! I really like the dual eye tubes. Looks like the radio is staring at you while listening in a darkened room! Take care, Gary
Threads: 271
City: Wilsonville
State, Province, Country: OR
This will be fun to watch!
Threads: 562
Night Mare.
38-690 looks like a walk in the park.
Threads: 49
City: Allendale, MI
A challenge to be sure! Don't know about the Night Mare part. Love it! Just wait till I get into the tuner. There's almost 30 tubes on that thing!
(This post was last modified: 06-25-2019, 10:51 PM by rfeenstra.)
Threads: 562
It's a forest. One could get lost in it. 30 tubes. Yikes. Are you sure at least 10 of them are not there just to look god?
Threads: 49
City: Allendale, MI
Some do accomplish a purpose of questionable value, especially in this day and age.
Threads: 15
City: Weymouth Ma
24 tube tuner, 6 tube amp/pwr supply as I recall . That's a very nice looking cabinet too. I will be interested to see your posts.I was able to keep one from going out to the trash a couple of years ago .Long story there. Mine came to stay with no amp/pwr supply and even ratty ones are more $ then I want to spend.
Henry
Threads: 49
City: Allendale, MI
The pre FM Philharmonics were 30 tubes. they included an audio expander and a scratch filter for the phono input. This one has the early FM band. 27 tubes on the tuner, 6 on the amp/PS. There is no audio expander as they needed the tube space for the FM section. As I said, the FM is the old 42-50 mhz frequency range. I just purchased a TV tuner "subber". These were a piece of test equipment that substituted for the TV tuner for test purposes. With a few modifications they can be made to convert the modern FM band into the old band. It takes 3 ranges to do that since the old band is only 8 mhz wide.
Threads: 15
City: Weymouth Ma
I stand corrected and learned something new today.
Thanks
Henry
Threads: 562
I'd be interested to see how you make those tuners to work. I read about it when I was restoring my Zenith Spinet.
i am still thinking of making it receive modern FM. It should sound very nicely.
And your radio....it should sound exceptional on FM.
Users browsing this thread: 16 Guest(s)
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
