Zenith Chairside
Got it back from my radio guy today. Fully electronically restored. Sounds good, and picks up stations well. He installed a 1/8" jack for my music devices, and Bluetooth receiver.
[Image: https://i.imgur.com/paz7Vfs.jpg?1]
Hmmmm....pretty!
Yes Zeniths ARE pretty.
Put pics of my (formerly) 9S244 on ARF.
There are currently 8470 online users. [Complete List]
» 1 Member(s) | 8469 Guest(s)
