Help needed finding thread!
I have seen reference to an article called "Rebuilding the Dial Drive Mechanism in Model 16". But I can't seem to find it anywhere! Can anyone help?
Pat
https://philcoradio.com/library/index.ph...34-44-144/
Will be doing one myself pretty soon.
Thanks Terry.
Much appreciated.
