47-1227 - Radio will not tune in any stations.
Threads: 3
City: Middletown, PA
State, Province, Country: Pa
Will a band switch from a Philco 46-1226 am/sw/phono radio work as a band switch on a Philco 47-1227 am/fm/phono radio?
Will a band switch from a Philco 47-1240 work as a band switch on a Philco
47-1227?
Thanks
(This post was last modified: 07-05-2019, 02:08 PM by Lucky.)
Threads: 268
Would check the Philco part number to see if they are the same. Generally I would think not.
Threads: 3
Thanks Terry I found the part number
Thanks
Rodney
Rodney
Please place your wanted ads in Wanted Ads. This section is not the place for that.
What makes you think the band switch is bad? Usually the only thing that goes wrong with band switches are (a) burnt contacts or (b) physical damage such as a broken wafer or broken contact(s).
Threads: 3
The band switch is bad because my friend who restores tvs, radios, jukeboxs, player pianos, clocks and windup victrolas tells me its beyond repair. He's completely repaired a couple of radios for me. He knows when an item Can not be repaired. I placed the need for this part here because it's part of this restoration. It's a continuation of the restoration of this radio. I put it here so those helping me will know what I need to complete the restoration.
Ok. I was curious about the band switch.
Quote:I placed the need for this part here because it's part of this restoration.
Your doing so violates the Phorum Rules. Please read and follow the Rules.
https://www.philcoradio.com/phorum/showt...p?tid=4586
I'm really not trying to be a mod with a badge and an attitude, but we have rules for a reason and everyone is expected to follow them.
Threads: 3
Please just remove me from the phorum your to picky with your rules
(This post was last modified: 07-05-2019, 05:54 PM by Lucky.)
Threads: 3
Please just remove me from the phorum your to picky with your rules. I will not be treated child with a warning level just because I disagree with you with my response.
(This post was last modified: 07-05-2019, 06:15 PM by Lucky.)
Thread locked. That's all folks.
Users browsing this thread: 15 Guest(s)
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
There are currently 4579 online users. [Complete List] » 1 Member(s) | 4578 Guest(s)
