Grill cloth.
What cloth would look more period correct than what i currently have there is so many different styles out there i just don't know.
http://www.radiodaze.com/grille-cloth-02-item-grc02/
Thank you Terry.
Here is my wife's Philco 41-235 very conservatively restored, she chose this grille cloth for it.   As all girls do.... they shop!!
Here is a picture of her radio!
She's the boss!
In some things.... great and small. True!!
I like the look, those blocks are cool. Icon_clap
You are very welcome, Paul!
Perhaps she should be promoted to Chief Grille Cloth Selector.
Has good taste in grille cloth.
Obtw if you can get KHDN (Billings) you can hear some otr tonight.
We pick up KHDN Billings, MT readily on HER radio.  All we have to do is move the radio around for best reception while tuning in the station.  It sure pick it up nicely here in Sheridan, WY; over 125 miles away.  It does great DX'ing after dark... (She solved the problem) she also just found the factory-optional external plugin for it.  It has a switch for distant and local stations.  You connect a wire antenna to it, and run it outside.  WOW!!
The station was assigned the call letters KHDN in 1963. The call letters changed to KYTY on August 10, 1984. On September 10, 1986, the station changed its call sign to KBSR, on March 28, 1989, to KKUL, and on June 1, 1995 to the current KHDN.  (a bit of history here).
[url=https://en.wikipedia.org/wiki/KHDN#cite_note-2][/url]
Respectfully,
Cliff & Sheila Byers
It wasn't her magnetic personality??[Image: https://philcoradio.com/phorum/images/sm...on_lol.gif]
We got lucky!!  Here are some pictures of it!!  She found the thing in an antique store's junk box marked $.25 cents.  WOW!! Icon_eek Icon_eek Icon_eek  It is the very part we need!!
Cliff
