Odd Philco Radio in travel case see attached photos i-sales sample or a travel unit?
see attachments  is  this  a portable phildo or  a philco salesmans sample?
Please  advise?  thanks
No Attachments Icon_eek
you mean no attachments allowed  or  none  showed up?
thanks  ed
        Odd Philco Radio in travel  case see attached photos i-sales sample or a travel unit? saw one  before  but  where  was  it besides ours here?  I have had this  for  30 years!  time to  clean it  up !
Any Info and history and schematics  needed!
Thanks Ed
Hello and welcome.
No, Sam meant no attachments showed up the first time around. Now they are here, thanks.
You have an 80P Jr. Portable.
Info: https://philcoradio.com/gallery2/1932c/#...P_Portable
Service data: https://philcoradio.com/library/download...l.%201.pdf
Schematic with parts identified: https://philcoradio.com/library/images/schem/80.jpg
WOW  Fantastic!   Time  to  go to  work!
Thank You much  for the info   Ron!
So it  was issued as  not a battery powered unit  as a traditional as we  think of a portable.... but  as  sort of a radio in a rugged  portable case but you  still have to plug in when you get it to a destination...
This belonged  to Vernon Furr a radio old  timer in Arizona and we have  many things of  his we preserve at the museum project  OT  but here is the crystal sets he  built and sold and also a little history on him. One more  nice thing to add to hiss display  (special note the  dust  you see was just a fraction of that was all over everything  we pulled out of there 30 years ago...)
OK  this  radio -how  scarce are they?
Many Thanks  Ed#
Its production figure is given in the first link I posted above in post #5.
Philco 91 Tuning Condenser
There are currently 4291 online users. [Complete List]
» 2 Member(s) | 4289 Guest(s)
