Tube from SG
How do you test a 0A3 Tube.. Its not listed for my Hickok 600A
Skip
The 0A3 is a cold cathode voltage regulating tube. It operates a bit like a neon bulb, and will glow when in operation. You can check if it is working by measuring the voltage between pins 2 and 5 while it is in operation. The voltage shouyld be about 75 volts.
Here is a link to the data sheet: https://frank.pocnet.net/sheets/049/0/0A3.pdf
It is same as Zener for solid state.
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 3830 online users. [Complete List]
» 2 Member(s) | 3828 Guest(s)
