Duncan Phyfe or Mersman Brunswick Drum Table Radio
Does anyone have any info about this radio? Not sure if it's Duncan Phyfe or Mersman. Can't seem to get much info from the owner, and it's too far away to go and look at it.
[Image: https://i.imgur.com/NYS6cc5.jpg]
[Image: https://i.imgur.com/PNzVWDT.jpg]
