Pilot TG528
Just picked this up today. It's a 12 tube tombstone that weighs 75 lbs. Ought to be fun restoring.
[Image: https://i.imgur.com/jBNd2wy.jpg]
WOW! Very cool find. Congratulations. I look forward to following your restoration.
Thanks. Got a couple more ahead of it, so it might be several days before I get started. One of the things I really like, is that it has ALL the original knobs.
