Philco 90 Arch
I need the arch that supports the back of this radio at the top, it is missing. Or can someone give me the dimensions of it, I'll try to make one. This radio needs lots of work it will be a work of love. Lots of TLC in and out.
Jim
Jim
Spring Lake MI
Steve probably sells those. Might even have them on ebay.
Thanks for the reply, could you tell me which Steve it is.
Thanks
Jim
Spring Lake MI
Steve Davis.  Icon_smile
Here's a link to Steve's stuff... and contact info:
https://philcoradio.com/davis/index.html
Thank you so much guy's really a great Phorum.
Jim
Spring Lake MI
