Radiobar Glassware
OK, I know there is a 99.9% chance these are NOT actual Radiobar Glasses, but I still think they are cool.  They have the Radiobar pattern and are what I would consider Pilsner glasses.  I picked them up last week and thought I'd share with the Phorum.
Those are very nice and the closest I have seen in a long while..
Great find!
Icon_smile
Where's the beer?
Lol! Great find! Icon_smile
has any one wondered about mixing good whiskey with electricity I wonder if any one was shocked by this concept
There are currently 9758 online users. [Complete List]
» 3 Member(s) | 9755 Guest(s)
