Please ID Silvertone
[Image: https://i.imgur.com/Xsqywgr.jpg]
Skip
It's a King-Hinner set made for Silvertone. I have this one:
[Image: https://proxy.duckduckgo.com/iu/?u=http%...up.jpg&f=1]
Pic stolen from the net.
Don't know if there is a diagram for it but there is not must difference between most of the battery Neutrodyne TRF sets. This will get you in the ballpark: http://www.nostalgiaair.org/pagesbymodel...017930.pdf
The tricky part on this one is getting the chassis out. It comes out thru the front but you have to remove the wood trim to access the screws along the edge of the panel.
GLOM
Any Clue to what this is worth?
Skip
Worth? Depending the market location 50-125 without tubes. add another 50 for a set of good '01a's. Knock off 50 if the audio transformers are bad and or not original...
Nice radio, I have a cabinet for one somewhere...
Chas
Pliny the younger
There are currently 10323 online users. [Complete List]
» 1 Member(s) | 10322 Guest(s)
