A little off topic
I p/ud a wooden desk a number of yrs ago. I think it's maple w/a shellac finish. Was working some farm sets maybe a yr ago and one of the D cells leaked on it and left a white crusty mark on it. What would be a good neutralizer for the acid from the battery? The desk is a beater and spent many yrs in the Catholic school. I'm thinking baking soda or vinegay. What say you?
It depends on the type of battery. If it was a "heavy duty" battery then baking soda would neutralize it, since the electrolyte is an acid. If it was an alkaline battery then vinegar would neiutralize it, since the electrolyte is an alkaline.
and you can mix the baking soda and the vinegar together Terry... Icon_biggrin
just for the fun of it...
....Which will result in you accidentally making Coca-Cola and they will sue you for patent infringement Icon_smile
So I checked out the offending cell and it was an alkaline and applied vinegar to it. Pretty stinky stuff! It bubble presumably neutralized the chemicals from the battery's discharge.
Kinda reminded of: https://www.youtube.com/watch?v=jYsyM1UFrhQ
