What Philco model is this?
Boy, that info caught my attention.
I just picked up what I thought was a 37-640MX in Southern California for 49 dollars.  I just read your info about the 1937 mid-year cancellation of the 640 and it's replacement.
Looks like I do have a 640 and not a 630, gold speaker cloth and 7 tubes compared to the 6 in the 630.
Thanks for the absolute wealth of info you provide all of us!
Brad
Philco 91 Tuning Condenser
There are currently 10435 online users. [Complete List]
» 2 Member(s) | 10433 Guest(s)
