Threads: 3
City: Tampa, FL
I was given this old Philco cathedral radio and am trying to find out the model and year it was made if possible. There are no markings on the chassis or wooden case that I can see. I hope the pics will tell the story.
I'm sure you guys know...right?
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Best regards,
Kico
"I whisper, but my horse still doesn't listen."
Hello, and welcome!
You have a Model 84B, the late version from January 1936:
http://www.philcoradio.com/gallery/1936b.htm#c
That is an oversized power transformer. Might be a 25 cycle model? If so, it will work on today's 60 cycle line current.
Threads: 3
City: Tampa, FL
Thanks Ron,
I tested all the tubes and they all check good. I then fired it up on my dim bulb tester...as expected a very loud 60 cycle hum but no smoke ...faulty power supply cap I suspect.
Any good links here on the forum for rebuilding one of these?
Thanks again...
Best regards,
Kico
Threads: 268
You may want to search this site for similar models like model 80,84,600, 57,37-84.
Threads: 3
City: Tampa, FL
7estatdef Wrote:You may want to search this site for similar models like model 80,84,600, 57,37-84.
Thanks Terry,
Whew...there's a lot here. I was wondering if anybody has compiled a component list (caps/resistors, etc.) needed for rebuilding an 84B they could post or send me? My eyes are not what they used to be, and reading the actual and schematic values is difficult. I'd like make sure I have the correct parts before I place an order.
Also, could someone on the forum link me to the correct schematic for this radio...thanks.
Best regards,
Kico
May I suggest you contact Chuck Schwark to obtain the service information package for this radio, which will include an 11 x 17 enlarged schematic, parts list, alignment info, changes, etc., etc.
http://www.philcorepairbench.com/schematics.htm
Well worth the nominal fee.
Threads: 3
City: Tampa, FL
Thanks Ron...I'll do it!
Best regards,
Kico
Threads: 12
City: Nashville, TN
Hi Ron,
I am working on one of these right now, the exact same cabinet. But the inside label says it's just a model 84. Does the 84B just refer to the style of cabinet, and is not marked so on the blue tag?
I do have another 84 but with the more circular cabinet.
Kico, I posted some photos an info for you on your other thread.
Thanks. Gary.
Hi Gary
Yes, the "B" referred to the style of cabinet; in this case, "B" = Baby Grand - which is how Philco referred to its cathedrals and tombstones back then. The terms "cathedral" and "tombstone" did not come into general use until decades later, as people like us began to collect these radios.
The sticker on the back of the chassis will read "CHASSIS TYPE 84" without mentioning the cabinet style.
Threads: 12
City: Nashville, TN
Thanks Ron, that clears up the mystery.
Working on the cabinet today, shouldn't be too bad. No veneer or photofinish to worry about.
Take care,
Gary
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
There are currently 8547 online users. [Complete List] » 1 Member(s) | 8546 Guest(s)
