Grunow Teledial
Actually, my friend and I spent most of yesterday evening on this unit. He was wanting a challenge and I was bored, so off we went. Speaker cone was totally separated from the frame, so he epoxied that. In spite of using shims to keep the voice coil centered, it still isn't quite perfect and him and I both saw signs the spider might have been tampered with sometime in the past. Also, had to undo a 1950's or 1960's repair as we went. He worked on the chassis while I scampered for parts and tried to make sense of the Grunow capacitor code numbers in the Riders Manuals. Actually, this set is in both volume 7 and 8 of Riders, which is good because 7 had a badly printed page. It's home and back together now, but it will still need some tweaks. One thing I forgot to do was clean the band switch. Oops! It works, but is touchy. Also, the dial kept binding against the cabinet due to some sag in the chassis board, so I'll pull that and rework again. That said, this set really pulls in the stations on AM and is decent on shortwave. Sounds pretty good as well, though that speaker still isn't 100%. It's encouraging though and I figure some more tinkering will get this set up to 100%. Icon_smile
Ronin: you have a metal 6L6 and what I assume is a glass 6L6 being driven by what appear to be either 6C5s or 6J5s.
Is that what your chassis calls for?
6L6's and 6C5's yes.
Hmm, yet another variant? One thing I wonder is: did all the variants use the same speaker? Also, I wonder why they switched to 6L6s? Mine pushes out a heck of a lot of sound with just the 6F6 tubes, though my friend thinks they might be getting pushed pretty hard. They do warm up pretty quick! I've had some radios that barely warm the 6F6 tubes and others like this one get them pretty hot.
I wonder if all versions of these had the same lousy band spread on short wave? Note how it goes from 5.5 to 18 mc on a single band, pretty much like the non Teledial Grunow that Bob Andersen has. In spite of this they used a sweep hand for logging, which seems almost like a waste of time. On my G.E M-83 they used five bands, longwave, broadcast, and three shortwave bands.
With regard to using 6F6s or 6L6 tubes as final outputs, that could be because of marketing, or simply because G.H.U managed to get a deal on 6L6 tubes in bulk. Apparently this was done with one of the brand Z models, they fitted the set with 6L6 outputs for marketing purposes, just to make it look like an audio "Hot Rod", but the 6L6s didn't do very much since the power supply didn't give them the extra B+ voltage they needed, just the usual 225-250 volts.
Jayce,
I hope the measurements I provided will be of some help
YOUR WELCOME!
Gene
Thanks, Gene. Actually, thought I said thanks earlier, but I forgot. Sorry..
Hey I just realized, Grunow copied Philco! This radio has an inclined sound board like my 116X! Hmm...Icon_think
Jayce,
I am working on a Grunow 1291 right now. I am looking for an operating manual for it so I can understand the teledial and the AFC. Were you able to find a manual for it?
Joe Miller
42-345 Resistors
Pholks: What are these little cylindrical objects inside Little Phil? They seem hollow. I don't think they are capacito...proftrussell — 12:39 AM
[split] New member...
Well, the paint thinner didn't get the job done but some heat did.  I got it apart, got everything cleaned up, re-lubed,...HowardWoodard — 12:24 AM
The gear on the 37-604 is exact same, but there was no pin. The pin exists on the gear of 37-116 or those ones with rob...morzh — 04:31 PM
I agree, the two should not be connected. Due to poor image quality of the original Philco schematic, it was unclear if ...jrblasde — 02:25 PM
New 37-116 Parts
Dan, I'm curious, I saw the 38-2 dial you got from them. Are you getting a new, improved one from them without the wh...Greg — 01:59 PM
New 37-116 Parts
They are not closed. I sent an email to them 3/8/2025 and got a reply back 3/10/2025. Since 3/8/2025 was a Saturday I di...dconant — 01:22 PM
Gloritone 27 Radio
Hello, The radio is playing now using the repaired antenna coil. MrFixr55 you stated a while back I might need to add...dconant — 01:10 PM
New 37-116 Parts
Well, their answering machine says they check their messages every day at noon and respond by 3p the next day - I can sa...Doppleganger — 01:09 PM
Thanks 462ron. I have it soaking right now but will test the power of my shop light magnet on the pin when it comes out.HowardWoodard — 11:39 AM
Wasn't that the Suppressor grid that we were talking about, that got connected with the AVC? Anywho, the initial questi...morzh — 10:53 AM
There are currently 2594 online users. [Complete List]
» 1 Member(s) | 2593 Guest(s)
