Threads: 104
City: Calgary, AB, CA
Threads: 114
City: Sneedville, TN
Very nice set! Congratulations. Looks like it'll keep you amused for a while.
Threads: 112
City: Medford OR (OR what?)
The circuit that is used to light the little signal strength bulb is interesting.
Threads: 97
City: Poughkeepsie, N.Y.
Coming along great....Keep us up to date.
Threads: 104
You did a great job on the cabinet. I am keeping the photo,for when I get to mine in the spring.
I have not started on mine, but I wanted to know if the grill cloth is glued on or can it be taken off and cleaned ?
Dan in Calgary
Living in Calgary Alberta
Threads: 112
I have seldom had success in cleaning any grill cloth. That , that is not so worn as to fall apart often shrinks. You almost have to clean it while it is still stretched on the baffle board. Probably would only want to try if success is not critically important.
Threads: 104
Dan
I would replace them if at all possible.
Someone had partially recapped my Hammarlund HQ-129-X, but they left several original paper caps in circuit without replacing. I replaced all of the caps that had not been replaced already, and redid the multi-section electrolytic to use new Nichicons stuffed into a twist-lock can as per original instead of the crude four individual electrolytics wrapped in masking tape and shoved into the original twist-lock holder. Now, the HQ-129-X has gone from a decent playing radio to a great playing radio. I'm glad I went to the effort to change these. It was well worth it.
Threads: 104
Thanks Ron. I am going to try figure out a way to maybe cut one end of the caps and leave them in , and reroute the new caps.
I usually think it over for a day or so before doing the actual work.
Dan in Calgary
Threads: 104
I did find a way to replace the five caps without putting them in the same place as the originals.
The radio plays very good and i feel better about having new caps.
Thanks Ron.
Dan in Calgary
[split] New member...
The gear on the 37-604 is exact same, but there was no pin.
The pin exists on the gear of 37-116 or those ones with rob...morzh — 04:31 PM |
I agree, the two should not be connected. Due to poor image quality of the original Philco schematic, it was unclear if ...jrblasde — 02:25 PM |
New 37-116 Parts
Dan,
I'm curious, I saw the 38-2 dial you got from them. Are you getting a new, improved one from them without the wh...Greg — 01:59 PM |
New 37-116 Parts
They are not closed. I sent an email to them 3/8/2025 and got a reply back 3/10/2025. Since 3/8/2025 was a Saturday I di...dconant — 01:22 PM |
Gloritone 27 Radio
Hello, The radio is playing now using the repaired antenna coil.
MrFixr55 you stated a while back I might need to add...dconant — 01:10 PM |
New 37-116 Parts
Well, their answering machine says they check their messages every day at noon and respond by 3p the next day - I can sa...Doppleganger — 01:09 PM |
Thanks 462ron. I have it soaking right now but will test the power of my shop light magnet on the pin when it comes out.HowardWoodard — 11:39 AM |
Wasn't that the Suppressor grid that we were talking about, that got connected with the AVC?
Anywho, the initial questi...morzh — 10:53 AM |
Hi Howard, if memory serves, and many times it doesn’t, I vaguely remember working on a Philco that had that pin you hav...462ron — 09:00 AM |
Gloritone 27 Radio
Hello John,
Thanks for the information and Arran I have heard of Wells Gardner and I have heard of Apex but I did not ...radiorich — 08:17 AM |
There are currently 3035 online users. [Complete List] » 1 Member(s) | 3034 Guest(s)
