How to safely remove a 37-620 viewing glass
Hoping someone can instruct me how to remove the viewing assembly from the cabinet. I obviously do not want to damage it. The chassis has already been removed. Thanks in Advance
Hi and welcome,
Use your palm to press in on the metal surface. gently twist to the left (in think or to the right). Remove the outer ring and glass. Under it there are 4 screws to remove the rest.
Thanks so much for your reply. I will try it
Philco 91 Tuning Condenser
There are currently 4261 online users. [Complete List]
» 1 Member(s) | 4260 Guest(s)
