Superior Instruments company model TV-11 tube tester
Does anyone know anything about this tube tester?, and is a manual available. Thank.
Philco 41-295X 4 band radio.
I'm 67 years old, in north Idaho.
the boat anchor bama site has info:
http://bama.edebris.com/manuals/superior/tv11/
and here's a link to the "How To" manual that comes with the set.
Thanks bob, do you think it’s a good tube checker?
I think it should be fine as far as emission testers go but I'm no expert on them. I sold the one I had and the next owner replaced the rheostat in it and I think that repair made it work OK.
Well the price went too high, so I didn’t get it. Bought a Hickok model 36 instead.
I have a TV-11 and a TV-10 They both work fine..
Skip
Philco 91 Tuning Condenser
There are currently 8476 online users. [Complete List]
» 2 Member(s) | 8474 Guest(s)
