Philco 46-1203 Cartridge Rebuild Help
I am in the process of restoring a 46-1203 for a friend.  The original cartridge is not working (surprise!!).  Been searching the phorums and found links to Syl's instructions, but the links are dead.  I did find this link: https://philcoradio.com/library/index.ph...idge_Types
Where can I find replacement crystals/elements??
TIA
Joel
It’s not easy to find viable crystal elements these days.  You can use a piezo element but the results are mediocre at best.  I put a P51-3 cartridge in my 46-1203 and it works great!
(09-11-2019, 04:23 PM)Squire Wrote:  I put a P51-3 cartridge in my 46-1203 and it works great!
What is a P51-3?  Where can I get one?
The P51-3 cartridge can be found here:
http://thevoiceofmusic.com/catalog/part_...Categories=
Awesome!  Thank you.
Just got the correct link from RonR
https://philcoradio.com/library/index.ph...ebuilding/
https://philcoradio.com/library/index.ph...on-topics/
Do you still have the page up with the broken link so Ron can fix it?? I've been surfing too much and lost in cyberspace lol . . .
There are currently 3853 online users. [Complete List]
» 2 Member(s) | 3851 Guest(s)
