Philco 90 (1-47 tube output) question
Was electronically replacing the copper electrolytics in my 90 model today. What I mean is that the caps are still there, just not functioning. The radio volume was starting to fade, and I wanted to do this before a real problem occurred.
My question is about the two condensers (#24 and #30) located in metal containers under the chassis. On the schematic I have (nostalgia air) #24 has 4 caps of .1, .15, .25, and 1.0 mFd, and #30 has .25 and 1.0.
1. My 90 has each of the caps with 3 leads, not 4 on #24 and 2 on #30. Any idea where the error is?
2. In any event, there is no listing of where the specific values are located on the schematic. You have 2 caps listed as #30, and 4 listed as #24. But there is no wasy to detirmine which cap is what value.
Never mind, I found the answer in the tech section.
Here's the link:
http://www.philcoradio.com/tech/90error.htm
Icon_smile
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 5022 online users. [Complete List]
» 4 Member(s) | 5018 Guest(s)
AvatarAvatarAvatarAvatar
