Ron's RCA T7-5 Electronic Rescue
What does rating "A" signify stamped on chassis back side?
105-125 volts, 50-60 cycles.
There was also a rating "B" = 105-125 volts, 25-60 cycles; and a rating "C" = 100-130/140-160/195-250 volts, 40-60 cycles.
Hey, I know this thread is over a year old but it has and will be a great help for me as I am restoring this radio as well.
Thanks Ron
Jim
Spring Lake MI
Hey Jim, you live just down the road a piece. I'd like to see what you have sometime!
I just read through this whole thread. Ron's radio is virtually identical to my T8-18, except for not having the tuning eye tube. It was very interesting to see how we approached certain problems differently. I used a small pair of very thin needle nosed pliers slipped behind the pointer, and liberal PB Blaster applied to the shaft using a little paint brush, and managed to free it up to remove it. Mine had all replacement electrolytics, and I am not as much of a purist as Ron, so, with plenty of room beneath the chassis, I simply replaced the caps on the underside with new electrolytics with higher voltage ratings, 2 10 MFD and 1 20MFD. We both encountered the exact same candohm gone bad, and the same remaining good. My bad one had both sections gone, so I merely soldered new resistors of suitable wattage across the gaps in the candohm. Both our speakers were bad, and neither had a center spider. I don't think they originally had one. He sent his away, and I rebuilt mine myself. It was really interesting to read through the thread. Brought back a lot of memories of repairing mine. It now works great. I have been listening to the playoffs and now to the world series on it, sometimes on stations as far away as Chicago and Cincinnati. Great radios ! Tonight I am listening on WRVA 1140 in Richmond, VA. It's coming in like it was next door, not more than 300 miles.
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
There are currently 2469 online users. [Complete List]
» 1 Member(s) | 2468 Guest(s)
