Last weekend I picked up this neat Zenith tombstone.
The cabinet is a 6-B-129. The chassis is AC powered and is either a 6-S-128 or 6-S-137. Zenith chassis 6-S-147, 6-S-152, and 6-S-157 are identical.
Only the 6-S-128 and 6-S-137 use 8 inch speakers, the others use 10 inch speakers.
The 6-S-128 and 6-S-137 were originally in (different) tombstone cabinets. The 6-S-147 is a chairside. And the 6-S-152 and 6-S-157 are consoles.
I am therefore going to call this chassis a 6-S-128 since its rubber-stamped model number is not visible.
So let's get going on its rebuild.
I needed to replace the dial belt since a dial belt was missing from this set. I ordered it the day after I bought the radio, and it arrived a few days ago. Installation necessitated my removing the dial assembly to get it started around the upper pulley, and then undoing the tuning shaft enough to get the belt around the lower pulley.
I took the following photos so I would remember how the clips attach which hold the dial glass in place.
Now a close-up of one of the clips:
I started to reassemble the dial assembly...
...and then realized I would need to turn the chassis upside down to work on it.
So the four indicators were removed and put in a safe place with the dial, dial glass, gasket, and the two small bags which hold the pointers and the dial glass clips.
I also removed the tone control from the dial assembly so it would not get broken.
The front then looked like this:
Let's take a look at this chassis.
Kind of grungy on top. Hopefully I can clean it up somewhat.
Underneath...it has been worked on before but the work was sloppy. When I took this picture I had already started working on it, replacing many of the components on the left side of the chassis and removing the replacement electrolytics which were dangling in the chassis on the left and right.
Fortunately, the original electrolytic cans were still on the chassis.
Here's one of them, which mounts to the chassis with two studs, nuts and lockwashers:
After removal of the can, with the nuts and lockwashers removed from the studs, the actual dual section electrolytic simply slid out of the can. Easy.
Here's the other electrolytic can, 16 uF. I really wish people wouldn't cut off the positive solder lug at the electrode - I like to reuse those lugs as it makes soldering wires to the positive end much easier.
I had a very difficult time getting its mounting nut loosened up to remove the can. Perseverance finally paid off, however.
I won't be polishing this can as I usually do, for to do so would make the Zenith logo disappear.
Both cans will be restuffed - the single section with two Solen 8 uF film caps to equal 16 uF; the other with new electrolytics.
Threads: 97
City: Poughkeepsie, N.Y.
Ron ...Nice catch. It will be a good one when restored.
Threads: 242
City: West Bend, Wisconsin
Excellent work, Ron. Having just went through my 6S152 back in August, the "drill" looks very familiar. Regarding the chassis, originally they were copper flashed I think, and later on they were painted, so there's not much that can be done other than stripping it down and have it re-flashed, or mask it off and paint it. I opted for the latter on most of the Zenith's I've done. I've used both of these paints....some of the Zenith's had a more "hammered" appearance to the paint, while others were just plain copper. You can find this paint at Menards, Home Depot, even some auto parts store chains carry it.
Good idea taking photos of how those dial glass clips go in. They take some finagling to get out...even more so to get back in! Thankfully the following year they stopped using those easily lost clips.
Greg
Thanks. (Thank you too, PhilcoJohn.) As I recall the 1938 models have the "hammered" appearance. This chassis is simply copper plated steel (plated both sides). I have a 9-S-262 chassis I hope to get to eventually. That chassis has a lot of corrosion on one side and will need serious cleanup and then painting with the "hammered" copper paint.
Good idea on the paint...but it's too cold here to do any painting now.
Threads: 242
Yes, old man winter has reared its ugly head a bit early this year! Never had 6 inches of snow on Halloween before, even here in Wisconsin! Painting and toning will have to wait until, oh say mid May. Maybe by then it will reach 60 again outside!
Threads: 69
City: Kansas city, MO.
I now have both electrolytic cans ready to restuff. If I have time tomorrow evening, I will do that chore then.
I also need to order resistors to replace the long multi-section Candohm.
Threads: 573
Very much the same things I dealt with in my Zeniths. Even the cap with side screws.
Both electrolytics have been restuffed and reinstalled. Photos later.
New resistors are on order from Mouser to replace the old Candohm.
The Candohm will get rebuilt sometime after the next (hopefully, final) chemo session which is tomorrow. So with God's will I shall return to work on this set in a week and a half or so.
Threads: 49
City: Allendale, MI
Best of luck to you tomorrow and the days following. Actually, I don't believe in luck so just know you're in my thoughts and prayers!
Threads: 156
City: Westland, MI
+1 Ron! Keep us posted, and know we all have your back! Take care, Gary
Threads: 114
City: Sneedville, TN
Interesting thread. I'll look forward to the next installment. You'll be in my thoughts and prayers, Ron. Get yourself well. You've become a real friend over the years I have been on this site.
I agree, the two should not be connected. Due to poor image quality of the original Philco schematic, it was unclear if ...jrblasde — 02:25 PM |
New 37-116 Parts
Dan,
I'm curious, I saw the 38-2 dial you got from them. Are you getting a new, improved one from them without the wh...Greg — 01:59 PM |
New 37-116 Parts
They are not closed. I sent an email to them 3/8/2025 and got a reply back 3/10/2025. Since 3/8/2025 was a Saturday I di...dconant — 01:22 PM |
Gloritone 27 Radio
Hello, The radio is playing now using the repaired antenna coil.
MrFixr55 you stated a while back I might need to add...dconant — 01:10 PM |
New 37-116 Parts
Well, their answering machine says they check their messages every day at noon and respond by 3p the next day - I can sa...Doppleganger — 01:09 PM |
[split] New member...
Thanks 462ron. I have it soaking right now but will test the power of my shop light magnet on the pin when it comes out.HowardWoodard — 11:39 AM |
Wasn't that the Suppressor grid that we were talking about, that got connected with the AVC?
Anywho, the initial questi...morzh — 10:53 AM |
Hi Howard, if memory serves, and many times it doesn’t, I vaguely remember working on a Philco that had that pin you hav...462ron — 09:00 AM |
Gloritone 27 Radio
Hello John,
Thanks for the information and Arran I have heard of Wells Gardner and I have heard of Apex but I did not ...radiorich — 08:17 AM |
Gloritone 27 Radio
Another make I have seen from U.S Radio and Television was Apex Electric, or U.S Apex, the badge on some of those had a ...Arran — 12:56 AM |
There are currently 2955 online users. [Complete List] » 1 Member(s) | 2954 Guest(s)
