A Philco?
This is pretty but I am out of room...
Just says Philco.
The chassis appears to be 1929 Philco.
The cabinet is definitely not Philco.
Ok,
I didnt see Philco making a cabinet like that...
Icon_smile
Philco 91 Tuning Condenser
There are currently 8936 online users. [Complete List]
» 2 Member(s) | 8934 Guest(s)
