Signal generator SG24/TRM3
All, I have a question about some capacitors in this thing  Its a Pyramid 4 UF 600 VDC Oil filled capacitor  Question  What type of oil is in this thing?  The SG was mafe in the 50's I think..
I want to open up and re stuff them..
But with oil in them  how do I proceed. Hope its not PCB oil???
Any help
Skip
Quote:But with oil in them  how do I proceed. Hope its not PCB oil???
Yes, I can say with almost 100% certainty.
If the cap was date coded after 1976 it would not have PCB, but a type of mineral oil.
Pull it out, dispose properly and replace with a mylar type(ish) and a tie strip.
Chas
Pliny the younger
I have often wondered about that  as well.   Thank you Chas , for your input on this.   Icon_eek
Jake,
Dispose of that cap properly.
Chas
Pliny the younger
That's what I thought.. Thanks
Skip
Yes Chas!
I'm seeing your response late here  for some reason.  Didn't get a notification of it.
I remember how carefully we were required to dispose of the light ballasts at work, ( and of how disregarding my supervisor was about the whole mess.)   Bad news. Icon_evil
There are currently 8689 online users. [Complete List]
» 4 Member(s) | 8685 Guest(s)
AvatarAvatarAvatarAvatar
