Need help identifying home system
Hey everyone! My good friend inherited a philco home system and doesn't know what model it is or if he can change the stylus/cartridge. Any help would be great identifying this system and what replacement stylus/cartridge would be ! Pictures are attached in link!
http://imgur.com/gallery/mcaJQRt
http://imgur.com/gallery/i7vHMwS
Welcome to the Phorum!
Icon_wave
Try posting those pictures again. Here's a "how to" thread https://philcoradio.com/phorum/showthread.php?tid=29
Thanks! I just attached a link to the pictures
Hi and welcome,
The model is a Q 1779F and best I can tell it's from 1967. I can't seem to find any free service info for but there is Sam's Photofact  which will have in their older issues.
I read that model as a Q1779F also but I suspect it might be Q1770PC since that is what comes up on the Sams Photofact search.  The link to that is:
https://www.samswebsite.com/en/photofact...h&s=Search
Philco 91 Tuning Condenser
