Dial Light Bulb for Model 60MB
Would someone know the type of bulb used? Bayonet or screw, voltage, current and or lamp type? I'd like to get a spare for this radio. Thanks.
Gary
From the Philco Service Bulletin for the Model 60, the pilot lamp is p/n 6608, which is a screw base, 6-8 volt lamp. Equivalent to a #46 lamp.
Info from the PARTS section of my site.
Thanks for the reply !
There are currently 10887 online users. [Complete List]
» 2 Member(s) | 10885 Guest(s)
