Grilling Your Radio
Try to avoid that "smoky flavor".
Wear your protection - -
https://www.russoldradios.com/blog/grilling-my-saba
Interesting!!
rfeenstra  +1   Icon_e_surprised
Thanks.
It has stopped raining so I have to get to work on the tractor. Icon_yawn
Very nice work indeed Icon_smile
They failed to order the spacers for the extension frame. So I got the back-hoe assembled but could not mount it on the tractor. Now I can work on a few radios while waiting.
Ok, I found a little info on the other forum, these ICs are 'clocking' ics, and are my horizontal drive. So, now, I need...TV MAN — 02:03 PM
Well, here's a head scratcher. I had been using my 1077 while working on the Emerson and the last time I tried to use it...TV MAN — 01:26 PM
Indeed. Thank you all. I'll remove and test the rest of the transistors. I'm trying to trace everything at the test p...R3Sons — 12:06 PM
Yes, if the speaker was disconnected or bad connections, it could cause high enough voltage spikes on the collector to k...462ron — 10:40 AM
42-345 Resistors
Good.morzh — 10:38 AM
I would check things around before simply replacing the transistor. Something killef it.morzh — 10:37 AM
÷1 to Sincere Richard. I use Mouser but either is the way to go. I'm sure the others, like justradios, are in the group...RodB — 10:24 AM
RS3, that output transistor X6…AR14, can be replaced with a GE-3 or ECG-121, probably others too. Ron462ron — 10:01 AM
Philco 7053
Thread moved to test equipment section. (I have not used one of these)klondike98 — 07:05 AM
Thank you Richard.R3Sons — 01:37 AM
There are currently 935 online users. [Complete List]
» 2 Member(s) | 933 Guest(s)
