Found: 38-690 Volume Control
When received, my 38-690 had a replacement dual pot volume control. The issue I have is that the volume cranks up loud really fast with the control just cracked. I suspect the pot was replaced with a linear taper instead of audio taper.
Can you confirm how sensitive the volume control should be when starting from all the way down?
If what I suspect is really the case, I’ll look for a replacement through an add or Mark Opatt.
Thank you.
Tony
What you can do is set the control @ the center of it's rotation and measure the resistance from the wiper to each end. If it's about the same it's a linear taper.
I measured both pots and they are roughly equal to wiper on each side when centered. I guess that answered my question. Before I start looking for one, would both pots be audio taper? My gut says yes.
Tony
According to the service info the original part is 33-5240.
There's a previous discussion of that part here:
https://philcoradio.com/phorum/showthread.php?tid=13625
Quote:Part #75 is 500K and part #76 is 100K, for the dual pot.
No mention of the taper type but I'd bet on audio taper too (it is a volume control after all).
Thank you guys for your help. I’ll start searching. The radio works, just has a volume control that’s too sensitive.
Tony
Mark Oppat is making one up for me.
Tony
There are currently 4058 online users. [Complete List]
» 2 Member(s) | 4056 Guest(s)
